Internal Touchscreen
External Desktop
Intensity Colour Coding
Selection
Source
Live / Preview / Blind
Parameter Table
RDM Notifications
Multicell Fixtures
Searching & Filtering
Fixture Creator
Edit & Export
Missing Fixtures
Multi-Part Fixtures
Windows Fixture Editor
Desk Type
Displays
Operational
MFF Window Playback Action
Auto Select Channels
Page Handover
Recovery Mode
Rem Dim & Highlight options
Hide Unused Fader Pages
Automatically manage relays.
Attributes
Record & Update
External Display
External Touchscreen
The external monitor connected to FLX S48, FLX and ZerOS Server, can be a touchscreen. The user interface displayed on the external monitor is designed to be used with a touchscreen.
To connect a touchscreen, use the DVI-D or HDMI connector for video, and USB for the touch. You will then need to Calibrate your external touchscreen.
Touchscreens that are plug and play with Windows 10 and do not require a driver, should work with ZerOS. Zero 88 however make no guarantee that all touchscreens will be compatible. Contact Vari-Lite for more information.
