Internal Touchscreen
External Desktop
Intensity Colour Coding
Selection
Source
Live / Preview / Blind
Parameter Table
RDM Notifications
Multicell Fixtures
Searching & Filtering
Fixture Creator
Edit & Export
Missing Fixtures
Multi-Part Fixtures
Windows Fixture Editor
Desk Type
Displays
Operational
MFF Window Playback Action
Auto Select Channels
Page Handover
Recovery Mode
Rem Dim & Highlight options
Hide Unused Fader Pages
Automatically manage relays.
Attributes
Record & Update
ZerOS
Mechanical
Mechanical Information for...
Dimensions
90mm (H) x 660mm (W) x 340mm (D)
Weight
7.5 kg
Operating temperature range
+5 to +40 °C
Humidity
5% to 95% non-condensing
Dimensions
68mm (H) x 669mm (W) x 284mm (D)
Weight
5.5 kg
+5 to +40 °C
Humidity
Dimensions
68mm (H) x 461mm (W) x 284mm (D)
Weight
4 kg
+5 to +40 °C
Humidity
Dimensions
43.6mm (H) x 482.6mm (W) x 226.5mm (D)
Weight
3.8kg
+5 to +40 °C
Humidity
Mounting ZerOS Server
ZerOS Server is designed to be rack mounted into a standard 19” cabinet using 4 x M6 Cage Nuts and 4 x M6 x 16mm screws.
Ventilation must be provided in the rack such that ZerOS Server can freely draw air from its rear ventilation slots.
Dimensions
90mm (H) x 339mm (W) x 342mm (D)
Weight
3.8 kg
+5 to +40 °C
Humidity
Always observe the operating environment information. If this environment is exceeded, it is likely that damage will occur to your console.
