Internal Touchscreen
External Desktop
Intensity Colour Coding
Selection
Source
Live / Preview / Blind
Parameter Table
RDM Notifications
Multicell Fixtures
Searching & Filtering
Fixture Creator
Edit & Export
Missing Fixtures
Multi-Part Fixtures
Windows Fixture Editor
Desk Type
Displays
Operational
MFF Window Playback Action
Auto Select Channels
Page Handover
Recovery Mode
Rem Dim & Highlight options
Hide Unused Fader Pages
Attributes
Record & Update
Mechanical
FLX Access Instructions
The diagrams below detail the screws that need to be removed to open FLX consoles for access.
- No user serviceable parts inside
- FLX consoles should only be opened by a suitably qualified person
- Opening FLX consoles within 3 years of manufacture will void warranty
- Disconnect mains prior to opening
Remove the lowest single screw from either side (circled). The sides do not need to be completely removed to gain access.
The 4 screws running along the bottom and 4 screws running along the top of the underside of the console need to be removed. To remove flip console upside down onto a soft surface.
Ribbon cables link the front panel and base. Carefully open the console, to avoid damaging cables and connectors.
