Add Fixtures
Missing Fixtures
Add Fixtures gives you access to thousands of fixtures. However, you may find the fixture you are trying to control is missing.
Follow the steps below if your fixture is missing:
Firstly, make sure your console is running the latest version of the ZerOS Library.
If you are running the latest version of the ZerOS Library and your fixture is missing, you may find that there is a different type of fixture in the library, that can be used to control your fixture.
If there are no suitable alternative fixtures in the library, you can build a basic fixture using the Fixture Creator.
Alternatively, if your fixture has RDM capabilities, ensure that RigSync is enabled on your console, and connect the fixture. ZerOS will be able to detect your fixture, and then create a basic fixture personality over RDM to allow you to control your fixture.
If the fixture does not have RDM capabilities, check to see whether your fixture is on the GDTF Share, or whether there is a GDTF file available to download from your fixture manufacturer's website.
If there is not a GDTF file available, you can create the fixture file yourself, using the free Fixture Editor software for Windows.
If you are unable to use the Fixture Editor software, we are pleased to inform you that fixture creation will now be outsourced to our fixture database provider. This change is aimed at enhancing the efficiency and accuracy of our fixture management process.
Please note that this service will now be chargeable.
GDTF service - Powered by Q2Q technologies
www.gdtfservice.com/#ContactUs
If you have created a fixture file, or have been sent a fixture file, you will be able to load it into your console.
Save the file to a USB stick, and plug into the console. Then tap Setup -> Load, and choose the fixture file to load in from USB.
