Setup
Upgrade
If your console is fully upgraded to the maximum number of universes, the Upgrade tab in Setup will be hidden.
Therefore the Upgrade tab will be hidden on:
- 2 universe FLX S24 and FLX S48 consoles
- 16 universe FLX and ZerOS Server
The Upgrade tab will also be hidden in Phantom ZerOS, as Phantom ZerOS will run the fully upgraded variant of the chosen Desk Type.
FLX, FLX S24, FLX S48 and ZerOS Server have the ability to have their channel count upgraded in individual universe increments.
FLX and ZerOS Server, can be upgraded to a maximum of 16 universes of channels (8192 channels), patchable across the 64 desk universes. They can come as a 16 universe version from the factory, or have extra universes added at a later date.
FLX S24 and FLX S48 can be upgraded to a maximum of 2 universes of channels (1024 channels), patchable across the 64 desk universes. FLX S can either come as a 2 universe version from the factory, or have the additional universe added at a later date.
To upgrade, tap Setup, and choose "Upgrade", which will be the bottom tab from the left-hand options.
Then click Save Details to save a text file to USB which includes all the information required for the upgrade.
Once your universe upgrade has been approved, you will be emailed your console's universe upgrade code file. This can then be saved to a USB drive, and loaded into the console from Setup -> Upgrade -> Load File
After loading the unlock code, the console will then ask to be restarted. The next time the console boots, the extra universes will be unlocked.
Unlock codes are not transferable between consoles.
